585,930 active members*
4,051 visitors online*
    May 2018
    6
    cant edit my gcode on syntec controller
    Suddenly, when iam editing my code on the machine, nothing changed or even typed.
    when going down to the end of the code, i found "read only file".
    plz help, i dont know how to disable this thing, i am in need to edit my codes.
    Note that the file on the computer before importing it, its not a read only file. so the problem is after importing it to the machine(syntec controller)
    thanks for your help
    Nov 2017
    44
    Re: cant edit my gcode on syntec controller
    Can you doing screenshoot?
    May 2018
    6
    this is before the problem
    this is after the problem
    NOTE: i am importing it directly from the PC using network(ethernet cable)
  1. Post file that works with Gcode for syntec
    By shadowdragonv12 in forum Alphacam
    Last Post: 09-06-2018, 09:18 AM
  2. Difference between Syntec 6MB controller and NK 300 Controller
    By hunnyk in forum Centroid CNC Control Products
    Last Post: 12-23-2017, 05:38 AM
  3. Syntec 6 controller
    By SCC in forum Chinese Machines
    Last Post: 05-26-2016, 05:34 AM
  4. GCode optimize, visually edit, pick machine order, etc?
    By tdiaz in forum Uncategorised CAM Discussion
    Last Post: 04-23-2011, 07:04 PM
  5. Using Gedit without EMC2 to manually edit Gcode with syntax
    By mouratoglou in forum LinuxCNC (formerly EMC2)
    Last Post: 07-25-2009, 08:36 AM
