600,838 active members*
3,249 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > SIEMENS Sinumerik CNC controls > SIEMENS -> GENERAL > Can´t Reload the NC Start up screen 2 seconds than chat down
    This applies to the system GA3 on Siemens Sinumerik 810M
    I have restarted my Siemens Sinumerik 810M many times after the batteries have run out due to inactivity in this machine but most recently I do not manage to get the actual uppstart system.
    Note that the problem is not uploading TA1,TA2 which is a natural consequence of processor booting.
    The LED on the component board (X111 to the right) is lighting red, I think this tell us the processor 50Mhz was not boot up.
    Any how now more why.
    I press and hold the Eye button and start up with the NC button and the screen lights up for at most 2 seconds. Everything looks great on the screen. Also a red LED above the screen that says the system is not ready because no parameters are loaded.
    Any how have seen this before.
Name:	Card inside the pulpet.jpg
    Jan 2013
    73
    Quote Originally Posted by Fire_in_the_hole View Post
    Hy, I think my machine does the same. RED LED light is on, machine is stuck on initializing screen. "Eyeball" button doesnt work so I cant upload parameters.
    Did you figure out what the problem was?
    Thank you.
    Feb 2025
    Re: Can´t Reload the NC Start up screen 2 seconds than chat down
    Experiencing issues with the "Can't Reload the NC Startup Screen: 2 Seconds, Then Chat Down" error can be frustrating. This problem often occurs when the application fails to load properly, causing the screen to freeze or crash shortly after startup. To resolve the issue, try clearing your browser cache or updating the app to the latest version. If the problem persists, check for any network issues that might be disrupting the connection. For more detailed troubleshooting, visit the support page at https://omegle.fan. Stay patient and follow the steps to restore smooth functionality.
