548,477 active members*
2,922 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Can't set om controller from mm to inch.
    Aug 2012
    14
    Unhappy Can't set om controller from mm to inch.
    The battery went dead on our old mill with om control. I cleared the control and reloaded all parameters and diagnostics (we had these backed up)
    Everything appears to be working fine except I cannot change the system to inches. Using the handy page setting, it will not change from 0 to 1, with or without pwe enabled.
    When I input G20 in mdi, it gives me alarm 10 (invalid G code)
    Any thought from the experts here?
    Aug 2011
    15
    Re: Can't set om controller from mm to inch.
    Quote Originally Posted by rgrow1 View Post
    Please check you have the option parameter switched on 900 bit5
  1. Replies: 4
    Last Post: 09-11-2012, 10:30 PM
  2. Recommended bit set for 1/4 ans 1/2 inch collets?
    By CNC74 in forum Open Source CNC Machine Designs
    Last Post: 04-15-2011, 06:21 PM
  3. Convert the controller to inch
    By esadaddy in forum Fanuc
    Last Post: 01-10-2009, 02:55 PM
  4. Set-up / Steps per Unit / Threads per Inch
    By adda in forum Mastercam
    Last Post: 01-15-2007, 11:29 PM
