529,951 active members*
2,260 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Can't upload program to fanuc 16-TT
Results 1 to 8 of 8
    Apr 2008
    211
    Hello guys!
    So, I got a new to me Nakamura TW-10 and I'm not being successful at uploading a program into it.
    I can send programs from the controller to my PC fine but get the LSK error when I try to upload?
    I can communicate to my other machine with a Fanuc 21iT just fine.
    Ive not messed with the baud rate yet witch is set at 9600.I have a Null adapter that works on the 21iT
    The procedure I am using is setting the mode to edit ,program MDI soft key, OPRT soft key, read soft key then get LSK error.
    What am I missing here.
    Claude
    Re: Can't upload program to fanuc 16-TT
    I'm not sure what your problem is, but LSK is not an error. I don't know what it stands for (Label Skips?) but I do know it is not an error. It is normal to see it flashing until it changes to INPUT once it see's something coming in. You must have a setting or two set incorrectly.
    Apr 2011
    647
    LSK means the machine is in the ready to receive mode. It is looking for the % sign to open the port. Try with your cable unplugged and see if you get the same thing or the DR OFF alarm. If you get the same thing then either you have the wrong port or you have a hardware failure. If you do get the DR OFF then you have the correct port and you must make sure that your files structure is correct (%). Try sending in a file that you just received.
    Mar 2019
    85
    You using the same computer as with the other machines or just the same program?
    Apr 2008
    211
    Man this thing is kicking my butt. I changed every setting one by one in my editor. Cimco edit. still no go.
    The port works just don't send the go signal back to PC. I can send programs to PC but not receive.
    I tried with with the same programs sent from controller, same computer as the other machines.
    The % are all there. so close yet so far.
    I just reached out to the Nakamura guy for help.
    I'll keep you up to date as I make headway..
    Apr 2011
    647
    Based on a setting sometimes you have to start the CNC ready to receive state before sending the file, other times you start sending the file then you start the CNC ready to receive. Try it both ways. Also, did you try the second port?
    Aug 2009
    715
    ...been blocked trying to post a link....so here is screen cap
    Apr 2008
    211
    Problem solved!!
    Parameter 0102 Device Num.(ch0) was set at 4 for Loop Back Handshake now set at 1 for Null Modem Cable.
    It's the little things.
    Thanks for all the input guys.
  1. Meldas M50 PLC Program upload and download
    By S9009 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-06-2020, 10:28 AM
  2. Replies: 2
    Last Post: 05-16-2016, 02:26 PM
  3. Fanuc 20t upload program
    By bmtrimp in forum Fanuc
    Last Post: 10-07-2014, 04:34 AM
  4. Upload Program with Filename
    By Smrtman5 in forum Haas Mills
    Last Post: 12-21-2010, 02:11 AM
  5. [B]Program upload problem with fanuc 6T[/B]
    By samiahmed in forum Fanuc
    Last Post: 03-02-2010, 10:32 PM
