567,562 active members*
3 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Centurion 7 Installed Options
    Feb 2017
    3
    Does anyone know a way to tell what options are installed for a Centurion 7 or CNC 7000 control? Things like Rigid tapping, etc. Is there a setting in the menu somewhere that shows this info?
    I was trying to access the documentation library but the Milltronics site seems to be down at the moment.
    Thanks for any help!
    Feb 2017
    3
    Re: Centurion 7 Installed Options
    I "think" I found where this info is. According to the Centurion manual, under Main>Util>Info>Ram shows the Ram Drive contents. The manual states "programs that run special options on a machine are usuallystored in this directory". I take it this is what I am looking for.
    However, I am not sure. The manual shows files with 5 digit number, which I assume are option codes of some sort. Of course, I may be completely wrong about this info...
    Sep 2010
    515
    I am not familiar with the Centurion 7, only 5 and 6. You want to get into the parameters pages. Go to the Mains page, then F7, then F1, then PROTO 3 for the validation code, then 3 for level, then you should see across the bottom, LEVEL, PREC, MACH, AXIS, and MISC. From there you can cycle through each option and there are multiple pages of info under each, so look at them all. I can't honestly remember where the rigid tapping option is listed, but it should be in there somewhere. Do you not have the manual for the Centurion 7? Pretty sure you can download it from the Milltronics website.
  1. College Centurion 1 (updated last to Centurion V) Troubles
    By bazookamoose in forum Milltronics
    Last Post: 12-04-2022, 08:12 AM
  2. Haas Installed Options List Location
    By JMFabrications in forum Haas Mills
    Last Post: 02-27-2014, 12:14 AM
  3. First trim installed
    By CNCadmin in forum EnRoute
    Last Post: 07-07-2012, 07:40 AM
  4. Centurion 6 upgrade options
    By moldcore in forum Milltronics
    Last Post: 03-02-2012, 01:08 AM
  5. Centurion 5 vs. Centurion 6 and validation codes
    By Turbo VW in forum Milltronics
    Last Post: 02-11-2007, 09:35 PM
