528,358 active members*
3,132 visitors online*
    Sep 2020
    China Laser 50W cut issue
    Hi. I need your help pls. When i cut with speed under 50 then my machine cut two lines on one axis. Above 50 speed are no issues, engraving also no problems. Power for test are 30%. I have checked mirrors and lens, they are fine. Pelts and pulleys also ok. I have no idea what i can check at next
    https://youtu.be/9aTXd7cDkis
    Sep 2020
    Re: China Laser 50W cut issue
    Junior Member
    Feb 2010
    155
    Are you sure that your beam is going through the nozzle without hitting the inside (i.e. is centered)? Typically when you see 2 cut lines then the beam is reflecting off of something, usually the nozzle. I am guessing at higher speeds you don't see the second (reflected) line because it is doesn't have enough energy to produce a mark, but at slower speeds it does. See this forum for more details.
    https://rdworkslab.com/viewtopic.php...ignment#p26786
