525,592 active members*
2,207 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Chinese 3040 CNC With Loose Z-Axis Linear Bearing
Results 1 to 12 of 12
    Oct 2016
    7
    I'm a newbie to hobby CNC but I've been using an ebay Chinese 3040 CNC for a few months now. Up until today I haven't had any problems. Today I noticed one of the Z axis linear bearings has somehow become pretty loose and slides up and down within the z-axis spindle mount.. This machine has a pair of LM12UU linear bearings on the Z axis that are basically press fit into a hole in the aluminum spindle clamp mount. It appears nothing holds the bearings in place except friction.
    One of the linear bearings is so loose it actually slides up and down in the spindle mount with a little finger pressure. It also falls down due to gravity and vibration when the machine is cutting. When the loose bearing slides down it creates binding when the z axis goes to lower. The left bearing stays in place but the right bearing slides down. When the z-axis lowers and attempts cutting it binds, the Z-axis stalls out and blows the spindle fuse.
    Has anyone experienced this issue? Since these bearings have a groove for a snap ring I was thinking I could remedy the bearing dropping down by installing a snap ring at the top of the bearing. Would this be a suitable solution or is the bearing loose because it is bad? The bearing sounds/feels fine when it slides along the shaft, the issue seems to be it slides too freely within the z-axis itself. Any input is greatly appreciated.
    Dec 2013
    4378
    Re: Chinese 3040 CNC With Loose Z-Axis Linear Bearing
    I would try some red Loctite 262 to ''glue'' the bearing into the housing. Should last forever.
    Oct 2016
    7
    Thanks Jim. I had thought of red loctite myself but I'm a bit leery. If and when it comes time to replace these bearings I imagine it may be a nightmare to get out? I'm not sure it would press out easily? I know from using it in the past in aircraft and automotive applications that it will soften and let go if you heat it up enough. I just worry how that chinese aluminum would withstand a few minutes of heat from a propane torch. With my luck it will probably warp like a vinyl record in the sun.
    Quote Originally Posted by Jim Dawson View Post
    Dec 2013
    4378
    Quote Originally Posted by JayBee44 View Post
    If this machine is used in normal hobby use, that bearing is probably good for 20 years or better. You could just put the Loctite on one end only, maybe a 1/4 inch or so. You could also use blue Loctite, pretty sure that would hold it also. I don't think it really would take much to hold the bearing.
    Oct 2016
    7
    You're probably right. I'll give it a go. In the event these cheap chinese bearings fail I'll worry about it then. Thanks again!
    Oct 2016
    7
    Don't like to bring threads back from the dead but I felt this was one of the rare cases where it is appropriate. I ended up simply installing the snap ring in the groove on the bearing and it worked fine. About 2 1/2 years later and I've had no more issues with the bearing moving or the z-axis binding.
    I have no doubt red loctite as suggested by Jim,one of the loctite retaining compounds specifically designed for press fit bearings, epoxy or something similar would have worked fine too. Thought I'd try the snap ring first and follow up with loctite or something if it didn't work long term. Turns out the retaining ring was I needed. I added a snap ring to the other (non problematic) side too as a precaution. I've had no further issues with the bearing.
    If I do have issues again I'll loctite the bearings and reinstall the snap rings. Just thought I'd share in case anyone wonders whether the repair worked!
    I have the same problem and was considering Loctite, but like the snap ring solution.
    However, you mention THE snap ring as though it is part of the kit - which I don't see in mine.
    Are you referring to a purchased part, and if so can you provide a link, please?
    Jul 2020
    11
    If you're gonna use Loctite, the stuff you want to use is NOT the threadlocker, but rather "Sleeve Retainer". It's green. Here:
    https://www.amazon.com/Loctite-37424.../dp/B0002KKTIG
    Oct 2016
    7
    Quote Originally Posted by Donjohnson24 View Post
    No. They aren't included with the machine. I had to purchase them. In my case it almost looks like they should have been installed but the manufacturer doesn't due to the press fit and the fact that they can save a few cents. I'm not sure on a part number but you should just be able to measure the bearing/groove diameter or google the bearing number and get the spec. Then most of the the time a suitable e-ring, snap ring or retaining ring should be available at the local hardware store.
    Hope that helps!
    -James
    Oct 2016
    7
    Agreed that the loctite specifically for press fit bearings, pins and sleeves is probably a better choice than the basic threadlocker. Although I have worked with the red loctite around cars and aircraft. I have no doubt the red liquid loctite thread locker, something like 271, would be a permanent fix as well. I went the cheap and easily reversible route. At most hardware stores 4 snap/retaining rings shouldn't be more than a few bucks. Likely many ways to skin this cat. . .
    I was mainly worried about getting things apart in the future. I know red loctite usually requires some heat to break easily. Generous heat is not something I'd be thrilled with on a cheap chinese aluminum machine. Not sure how easily the green sleeve retainer stuff would come apart. You'd likely never need to worry about it anyway, but I'm a bit paranoid and plan for the worst. I chose to leave myself the option of easily getting things back apart. The fact that the snap/retaining rings were cheaper than the red or green sleeve loctite just made it even better.
    Hope that helps!
    -James
    Thanks for the response - I would expect that there should be a groove in the plastic mount for the bearing that would be exposed when the bearing is pushed further into the block, but if the manufacturer would not bother to fit a snap ring, it is unlikely that he would have cut the groove. I should add that I have a CNC3 3018 Pro machine rather than a 3040 so there may be a difference in this version.
    It seems that some green Loctite should do the job for me.
    I have to smile, though, at your and other posters references to finding snap rings in the local hardware shop. That may be the case in the US, but hardware shops in the UK have largely disappeared, being - partially - replaced by what you call big box stores. They carry only a range of packets of standards screws, nails and other general hardware items - nothing specific such as snap rings. I could probably find a box of assorted snap rings at Amazon.uk, but would certainly have to find what is specifically needed by an intensive search online. As I am 80 years old, I do remember the old hardware shops of my youth, which were usually known as 'The Oil Shop', as that was where you went for the paraffin for one's Valor heater - and possibly to get accumulators charged for the supply to the valve heaters in your wireless set !
    Oct 2016
    7
    Talking Re: Chinese 3040 CNC With Loose Z-Axis Linear Bearing
    It definitely sounds like there's a difference in construction between your machine and mine. If I recall correctly for the z axis on my machine the linear bearings extend slightly past the aluminum housing on top and bottom. The pre-manufactured linear bearings have a retaining ring groove machined on both ends. It was just a matter of sliding the bearing back where it went and installing the retaining rings in the grooves.
    I'm sure the suggested loctite solution should work out fine for you and sounds like the logical approach in your situation.
    Believe me the local mom and pop hardware stores are nearing extinction here in the US as well. Most of the them around me have closed or converted to one of two main hardware store franchises. They're essentially just a step above the big box stores. They've got a slightly better selection for some items but they usually can't compete with the big box stores on pricing. The good news is some of our big box home improvement and hardware stores in the US really do have a decent selection. IF you know what you're looking for and where its at that is. Asking for help beyond basic screws, lumber and paint will typically draw blank stares in the big stores!
  1. Replies: 3
    Last Post: 04-20-2019, 11:23 PM
  2. Chinese CNC milling 3040 4 axis
    By Blisk1 in forum Chinese Machines
    Last Post: 09-06-2016, 12:40 PM
  3. 4th Axis on Chinese CNC (3040 Model)
    By Winterdragon in forum Mach Software (ArtSoft software)
    Last Post: 09-04-2014, 05:01 PM
  4. Chinese 3040 CNC with 4th Axis
    By Winterdragon in forum Stepper Motors / Drives
    Last Post: 01-28-2014, 05:02 PM
  5. Need ballscrew loose bearing supplier
    By MrWild in forum Benchtop Machines
    Last Post: 07-04-2010, 02:06 AM
