548,477 active members*
2,278 visitors online*
    Jun 2007
    147
    Chinese gearbox noise.
    Hello, I have garage in a duplex which limits my garage noise to 80 decibels, Im looking at square column vertical mills and wondering if there is a way to reduce the noise?
    Gear lapping?
    Thicker oils?
    Im looking at RF45 or VM32,the 32 is 50kg lighter than the 45 but has a low noise dc motor.
    Jan 2008
    1295
    Re: Chinese gearbox noise.
    Change to belt drive
  1. Excello 602 (605) z axis gearbox oil + main gearbox gaskets
    By dholzric in forum Uncategorised MetalWorking Machines
    Last Post: 03-27-2018, 10:08 PM
  2. Replies: 4
    Last Post: 02-15-2018, 02:11 AM
  3. Chinese spindle 2.2 kW funny noise
    By FeliceM in forum Spindles / VFD
    Last Post: 06-26-2017, 01:15 AM
  4. Comparison questions, BMDC3 vs. BMDC4, gearbox vs no gearbox
    By nlh in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2016, 06:37 AM
  5. VF-11 40-Taper Gearbox Noise
    By RMM97502 in forum Haas Mills
    Last Post: 01-16-2009, 03:10 PM
