548,544 active members*
1,661 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > General Laser Engraving / Cutting Machine Discussion > Chinese laser which to choose metal sheet laser cutting machine
    wklaserliu
    Guest
    LF1325/1530
    Whole specification
    size(mxm) about6.5*3.2
    Working area 1300*2500mm/1500*3000mm
    Table height 950mm noise <65Db(not include exhaust fan noise)
    Power demand AC380V±5% 50HZ(single phase) Whole power 7KW ball screw/9KW Gear
    Tempreture Tempreture:10—35℃ Humidity: 40—85%
    Fiber specification
    Type Fiber
    Working mode continious/ power 500 W /1000w
    Spot mode Multimode Wave length 1070nm
    Working specification
    Re accuraccy 0.1mm/m
    Fast speed 0-700mm/s
    Acc speed 0-4000mm/s^2
    Working speed
    0-350 mm/s
    Wroking ACC
    0-2000mm/s^2
    DRIVER YASKAWA
    Transmission Ball screw /Dual-drive rack
    controlsystem system CYPCUT (PMAC option)
    Auxiliary systems
    Colling system CW6000/LW16
    Lubrication Systems Manual
    Laser head American II-VI
    Software
    Software CYPCUT
    Graphic support AI 、BMP 、PLT 、DXF 、DST etc
    Model
    Specification quantities Origin remark
    Fiber laser 500W 1p Paycuss/IPG
    cutting Head 1p American II-VI/LASERMECH
    Focus 1p American II-VI
    Servo motor 3 p YASKAWA
    Ball screw/Gear 3p Atlanta / WMH Herion
    Laser head 1p
    Chiller 1p 双
    Control system 1p CYPCUT/PMAC
    Linear 1p Hiwin
    Lubrication Systems 1p
    SOFTWARE 1P
    MACHINE BED 1
    quiven form gweike laser
    skype: wkquiven
    liuqiufen0530@163.com
    chloe@wklaser.com
Name:	cutting sample .jpg
ID:	291254Click image for larger version.
Name:	cutting sample 425.jpg
    Jan 2021
    27
    Re: Chinese laser which to choose metal sheet laser cutting machine
    Metal embossing machine enables the process of stamping raised or sunken designs or relief in metal. There are multiple ways one can achieve this effect. For instance, dot-peen marking machines and laser engraving machines are also available.
    Embossing is another method and each of these processes differs in its final output. Dot-peen, for instance, works by marking the required pattern using multiple strikes of a pin on the metal surface.
  1. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 08-19-2015, 09:03 AM
  2. fiber laser cutting machine 500w and co2 metal non-metal laser cutting
    Last Post: 05-20-2015, 08:35 AM
  3. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-16-2014, 07:46 AM
  4. Thin metal laser cutting machine- CHEAPEST metal laser cutter
    By Gweikelasers in forum News Announcements
    Last Post: 03-06-2013, 10:08 AM
