601,652 active members*
2,556 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Choose which postprocessor in Madcam for Fanuc robodrill with 16i control
    Apr 2025
    There are 3 different choices in madcam for fanuc. If i remember correctly they are: Fanuc 0M, Fanuc and Fanuc 2.
    Which of these should I choose for a 16i controller on a robodrill milling machining center.
    Thanks for any help,
    Mathias
    May 2006
    346
    Re: Choose which postprocessor in Madcam for Fanuc robodrill with 16i control
    Do you have a sample of a post from this machine?
    Best place to start is to compare the 3 different Madcam posts to a known post that was used previously on this machine.
    Apr 2025
    Hi, there are many programs on the robodrill but I do not know how to get them downloaded to my CF card.
    But here are 3 programs I made in Rhino using madcam for each of the different postprocessors, see attached file.
    /Mathias
    Attached Files Attached Files
  1. Replies: 2
    Last Post: 02-19-2021, 12:45 AM
  2. Replies: 4
    Last Post: 09-19-2020, 05:36 PM
  3. Replies: 6
    Last Post: 09-16-2020, 06:29 PM
  4. Replies: 8
    Last Post: 05-19-2018, 01:59 PM
  5. Fanuc robodrill 16i-M 3d arc
    By TomL21 in forum Fanuc
    Last Post: 01-24-2011, 02:48 PM
