591,536 active members*
5,230 visitors online*
Results 1 to 4 of 4
    Question Chromium Carbide
    I was just asked by our sales departement if we can cut Chromium Carbide plates with our CNC plasma. With a little research turns out we can which I did not know!
    My question is; Is there a different type of consumable to be used to cut such material or can we use our regular mild steel consumable? By the way we use a HPR130 from Hypertherm.
    Thank you in advance for you input.
    S. Martin
    Apr 2007
    11
    we make chrome carbide overlay plate and pipe. we use standard consumables. it's a little harder to cut than mild steel but you shouldnt notice any differance.
    Thank you
    Jun 2024
    Re: Chromium Carbide
    We tried to cut chromium carbide and the torch kept diving into the metal. Which gas should be used to cut this. Just oxygen?
  1. Machining Chromium Cobalt??
    By elite1 in forum Material Machining Solutions
    Last Post: 05-12-2012, 02:16 AM
  2. what do you use to cut off carbide drill bits and carbide endmills
    By micksphoto in forum Toolgrinding / Toolgrinding Machines
    Last Post: 04-01-2012, 03:28 PM
  3. drilling chromium help please
    By mbrupb in forum Material Machining Solutions
    Last Post: 11-30-2011, 11:59 AM
  4. Chromium Copper!!!
    By rsaulus in forum Moldmaking
    Last Post: 08-17-2010, 02:55 AM
