Clamb active, Yellow, LED lights when the braking resistor is in use.
Z-Motor is turning freely.
Any idea what might be the reason ? Is there in Maxax 200 an other braking resistor wich is driven some transistor ?
Fan is not running.
Mitsubishi CM30TF-12E changed. It was partly broken. The Z-driver had got thermal shock because of durty, stuck Fan.
