506,518 active members
3,954 visitors online
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati arrow 1000 spindle error
    Oct 2019
    I have Cincinnati arrow 1000,the drive error,when I release emergency button the drive vfs5 240 00 2031e red led light on,i have read drive history with kollam organ software it's showing err 83 or out of range,and err 14 power bus,,the power supply is ok,because other drive are working fine,only issue on spindle,the spindle drive fault light on when I release the emergency,anyone can help on it
    Sep 2009
    17
    Re: Cincinnati arrow 1000 spindle error
    You would need to check the bus voltage on the main power supply- the Error 14 shows that its either too high or too low. If this bus voltage is normal, there could be an issue between the input terminals (where the bus connects) and the Drive PCB inside (i had this issue on a Simodrive 611 where i kept on getting alarms due to a slightly burnt DC link connection on one of the drives. Cleaned, soldered direct to the PCB with removal bolts and its working fine since)
    When you remove emergency, are you able to move the other axes? I am assuming you are unable to because the Spindle drive would directly give the alarm regarding the voltage
    Err 83- I am not sure what this is. If i remember correctly its a wrong command input to the drive by the user, and this may not be the cause of your problem
    Best of luck and keep us posted!
    Oct 2019
    Quote Originally Posted by jaideepshinh View Post
    Thank you for your help jaideep,dc supply is ok,because the other 3 drive are connected with same dc supply,that 3 axis are working fine,the red error light is on when release emergency switch, i have open the drive and check it all,but I could not find any spark or any from drive inside,
  1. cincinnati arrow 1000 spindle bearings
    By Maverick1 in forum Cincinnati CNC
    Last Post: 12-19-2016, 05:49 AM
  2. Cincinnati Arrow 1000 Not Starting
    By zephyrmachine in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 07-06-2016, 09:27 PM
  3. cincinnati arrow 1000 too change
    By dbills in forum Cincinnati CNC
    Last Post: 09-16-2013, 09:25 PM
  4. cincinnati arrow 1000 realtime timeout error
    By stuart wiezniak in forum Cincinnati CNC
    Last Post: 04-24-2013, 10:26 PM
