578,966 active members*
8,047 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati CL 840 F Laser Center Not Calibrating at start up
    Dec 2010
    34
    Hello,
    I am working on a 840 F laser center. Its a used machine and a tech setup and tested the machine at install about a month ago. I am trying to start the resonator and cant get past the calibration step. The resonator goes through the vacuum and gas filing procedure without an issue. Does anyone have any experience with this issue? My thought was alignment.
    I have experience with Trumpf 600L and L3030 lasers. First time working on a Cincinnati
    Thanks.
    Mar 2008
    236
    Re: Cincinnati CL 840 F Laser Center Not Calibrating at start up
    Joe, you are are the wrong forum.
    You want https://www.e-ci.com/ Cincinnati Incorporated makes Sheet Metal Processing Equipment; such as your Laser Cutting Sheet Metal Machine.
    Cincinnati - Fives, Cincinnati - MAG, Cincinnati - Unova, Cincinnati - Milacron, Cincinnati - Milling Machine made Metal cutting equipment and Aerospace special machines.
    Dec 2010
    34
    Thank you for the link. I will repost in the right forum.
  1. Calibrating X and Y axis on 4060 China laser engraving/cutting machine.
    By doken in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 02-17-2021, 09:31 AM
  2. Calibrating movement on custom laser cutter with Lihuiyu Studio and Corellaser
    By mnomn in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 09-13-2019, 10:36 AM
  3. Calibrating X and Y axis on 5030 China laser engraving/cutting machine
    By raipe in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 12-22-2016, 01:31 PM
  4. cincinnati 900 machining center
    By dre in forum CNC Machining Centers
    Last Post: 01-11-2013, 07:18 PM
  5. Cincinnati Milacron Turning Center
    By sc6chuck9 in forum General CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-13-2007, 05:25 PM
