585,754 active members*
3,672 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Cincinnati Hawk 250 Acramatic 2100 - continuous auto restart until desired part count
Results 1 to 4 of 4
    Mar 2017
    Trying to setup a stock puller program to run continuously until "x" part count is reached. I have the program setup to run the part and pull the stock perfectly, however cannot get it to automatically restart. any help appreciated
    cheers,
    Nick..
    Oct 2011
    205
    Main and sub
    Aug 2009
    1570
    Re: Cincinnati Hawk 250 Acramatic 2100 - continuous auto restart until desired part c
    144/length+cutoff-rem repeat sub + or -1 ?
    Mar 2008
    285
    (PGM, NAME="COUNT")
    N10000 G0 G70 G62 G98.1 X10/2 Z12 S50 M3; G98.1 is a Machine coordinate move
    [RUN_1_MORE];START MACHINING CYCLE AGAIN
    (IF [@COUNTER] >= 5 GOTO [END]); STOP IF COUNT IS EXCEEDED
    ;MACHINE PART
    ;MACHINE PART
    ;MACHINE PART
    G4 F.5;DWELL .5 SECONDS
    ;MACHINE PART
    ;MACHINE PART
    ;MACHINE PART
    [@COUNTER] = [@COUNTER]+1; INCREMENT PART COUNT BY ONE
    (IF [@COUNTER] >= 5 GOTO [END]); TEST PART COUNT
    (GOTO [RUN_1_MORE])
  1. Cincinnati Sbare 750 Acramatic 2100
    By Fero_Engineering in forum Cincinnati CNC
    Last Post: 01-07-2020, 04:53 PM
  2. Need Post for Cincinatti Hawk 200 w Acramatic 2100 control
    By dbensavage in forum FeatureCAM CAD/CAM
    Last Post: 04-06-2017, 08:42 PM
  3. cincinnati milacron hawk 150 acramatic 2000 control
    By leroy1652 in forum Cincinnati CNC
    Last Post: 10-24-2014, 10:15 PM
  4. Replies: 2
    Last Post: 03-30-2014, 07:48 PM
  5. Cincinnati Acramatic 2100 (Vickers)
    By atif.naseer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-01-2013, 07:47 AM
