562,375 active members*
3,858 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > cincinnati saber 750 axes drives are not enabled
    Nov 2022
    Unhappy cincinnati saber 750 axes drives are not enabled
    I own a Cincinnati Sarber 750 machine. I have a problem. When I turn on the machine, the drive lights flash green and red, but when I press a green start button, all drives flash three green lights, but the z drive lights three green lights, then turns on a red light on the turn-back signal, then an error comes (39-6) Please help me
    Dec 2006
    571
    Re: cincinnati saber 750 axes drives are not enabled
    I think you are looking at the FOLD BACK light. This indicates the axis is in a over current condition. If you brace up the Z axis with a 4x4, turn off all the power and disconnect the 3 axis drive motor wires at the drive (make sure you take a pic and label them first). Turn on the machine and the drives, if you have a fault then the problem is in the Z axis drive and not in the motor or the wires. You may have a short in the IGBT transistors in the drive.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Drives not enabled
    By coop31 in forum Cincinnati CNC
    Last Post: 10-31-2020, 03:42 PM
  2. Saber 750 parts avaliable for sale
    By bischma in forum Cincinnati CNC
    Last Post: 03-08-2019, 12:26 PM
  3. Need Help Cincinnati saber 1000 Fanuc control
    By Stealth XY in forum Cincinnati CNC
    Last Post: 05-31-2016, 08:07 PM
  4. Sabre 500 A2100 (Axes drive not enabled) Help
    By DRB4 in forum Cincinnati CNC
    Last Post: 02-21-2011, 01:16 AM
  5. Cincinnati Saber 750
    By clip in forum Cincinnati CNC
    Last Post: 12-03-2008, 05:32 AM
