591,385 active members*
7,595 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Cincom L25 Y02 alarm 0051 003 , need parameters too
    Sep 2014
    I have a cincom l25 with meldas 520 control, serial number V6071, somehow backup parameters on disk got corrupted ,need bit select list and parameter list if anyone could help, any help would greatly be appriciated (machine has a fbal2 led on and showing (y02 0051 003 alarm, EMG PLC)
    After spindle drive burned up (and battery died ) drives display AA-AC-AB on power up , checked sh22 cables and they are good , plc data is blank , and plc-sw menu is in japanese but everything else is in english. Replaced mcp board on unit and still no luck
    Nov 2014
    26
    Re: Cincom L25 Y02 alarm 0051 003 , need parameters too
    Hi
    If you are on an L520 with a 600 control you can restore the S ram and para file from the back up and restore function on the control
    The y02 51 alarm is a servo problem
    If you need these files I do have a copy from another machine
    Apr 2011
    26
    I know this is an old thread, but I have basically the exact same symptoms on an M20. Would sure like to know what the solution was.
  1. Need Mitsubishi Meldas 320' parameters for Cincom L16
    By Nickon59 in forum Mitsubishi controls
    Last Post: 10-03-2023, 05:06 PM
  2. parameters for cincom L16
    By guhl in forum CNC Swiss Screw Machines
    Last Post: 04-25-2017, 05:27 AM
  3. Replies: 6
    Last Post: 07-16-2010, 09:00 PM
  4. Replies: 6
    Last Post: 08-29-2008, 03:45 AM
  5. Servo alarm parameters
    By kevbo in forum Fanuc
    Last Post: 01-05-2008, 12:39 PM
