538,103 active members*
2,576 visitors online*
Results 1 to 5 of 5
    Oct 2008
    17
    Question Cloning Fanuc Data Server HDD ?
    Hello,
    I've been at this for weeks now but can't get it to work.
    We have a Fanuc machine with a bad Data Server disk, I've tried replacing the disk with a disk from another machine and it works.
    So my plan was too clone the working disk onto a new disk and use that in the machine with the broken disk.
    There is very little information about this (none), so I'm woundering if anyone has done it?
    I've tried with different disks, 3,5", 2,5", IDE/PATA, Solid State IDE drive.
    I've tried Acronis.
    I've tried HDClone.
    I've made bitcopies.
    I've checked the raw data on the disk and it look identical.
    What am I missing?
    Any information is welcome.
    Apr 2009
    1230
    Re: Cloning Fanuc Data Server HDD ?
    Are you referring to the disk DRIVE or the 'floppy' disk?
    Aug 2004
    244
    I have had good luck using clonezilla to copy disks in raw mode with non-standard file systems. It sounds like you already tried to do a raw copy though, so I am not sure why it is not working.
    Everything in moderation, including moderation.
    Jul 2009
    419
    You could look in to using a linux rescue disk and boot a pc from that rescue disk.
    Also, linux offers a program called "DD" that can be used to copy literally Everything from one disk to another.
    It is probably included in the rescue disk too, and probably installed with every linux system.
    But study it well, it is easy to make big mistakes using dd..
    Sven
    http://www.puresven.com/?q=building-cnc-router
    Sep 2020
    6
    Hi Tonper, did you figure out how to clone this drive? Any chance you could send me the clone image from your drive? My hard drive crashed in my Fanuc data server and am looking to work with a clone image.
    James
  1. Fanuc 0i-Md Data Server Question
    By ztouesnard in forum Fanuc
    Last Post: 11-06-2015, 06:35 PM
  2. Fanuc 30i Data-server read
    By Paulus_M in forum Fanuc
    Last Post: 06-04-2012, 06:48 AM
  3. 0T-C Data Server
    By Scottjit in forum Fanuc
    Last Post: 05-27-2011, 12:07 AM
  4. Data Server with a Fanuc 18MB
    By buildyourown in forum Fanuc
    Last Post: 06-24-2008, 05:49 AM
  5. Fanuc 18i with Data Server
    By Monty66 in forum Fanuc
    Last Post: 02-13-2007, 04:23 AM
