548,591 active members*
2,304 visitors online*
Thread: CNC
    Oct 2021
    3
    CNC
    Hi everybody.
    I am currently working with a Mazak FJV-250-Mazak Fushion 640M cnc milling machine. The machine's memory has a very low free space of 2.5M. Does anyone know how to install the machine to run the program directly on the memory card? ADAPTER no.help me.than
    Attached Thumbnails Attached Thumbnails 49f072ea82094a571318.jpg   z2919931593460_ea895f1f7546710073391502d0bef45e.jpg
    Feb 2006
    982
    Quote Originally Posted by DUCVUONG View Post
    Hi everybody.
    Boy, 2.5 Megabytes is a lot however if you want to 3D machine and it is not enough. Why dont you call tech support from Connecticut they should able to help you which parameter need to turn on.
    The best way to learn is trial error.
    Oct 2021
    3
    Re: CNC
    C?m ?n.tôi ?ã g?i và h? c?ng ch?a tìm ???c gi?i pháp c? th? vì ??i máy là quá th?p.
