547,312 active members*
3,206 visitors online*
    cnc 1200 - 1200 mm need help
    hello guys am new member
    am a 3D architectural designer
    i bought a chinise cnc with a table (1200/1200mm) without its own computer
    so i bought an computer for it i instaled the driver card correctly and the nc studio too and the machine is working ...
    now the problem is when i give it an order to cut a square (150/150mm) ... the machine cut it (120/60mm)
    i dont know what to do
    any advices ?
    Apr 2004
    5383
    Re: cnc 1200 - 1200 mm need help
    That sounds like a problem with your steps per unit settings. You need to increase the steps proportionate to the error until it cuts accurately. If you know the pitch of your screws and the micro-stepping factor of your drives you can calculate it, but trial and error works too.
    Andrew Werby
    Website
  1. Desktop 1200*1200mm cnc machine from USA Customer
    By BlueElephantCNC in forum Blue Elephant CNC
    Last Post: 08-24-2020, 10:56 AM
  2. CNC OPERATOR/YOUJI 1200 VERTICAL TURNING CENTER
    By MR ROTOLOK in forum Controller & Computer Solutions
    Last Post: 06-29-2012, 10:36 PM
  3. 1200 by 1200 machine build
    By Rodm1954 in forum DIY CNC Router Table Machines
    Last Post: 05-04-2012, 01:55 AM
  4. New 3 axis CNC machine w/1200 ipm rapids released
    By RomaxxCNC in forum News Announcements
    Last Post: 10-09-2006, 01:35 PM
