567,562 active members*
3 visitors online*
Results 1 to 1 of 1
    Nov 2019
    8
    CNC 3040 Z-DQ spindle rating
    Hello, I have the CNC 3040 Z-DQ desktop CNXC unit ( as shown attached), but I am having trouble with the spindle speed.
    The maximum measured speed is 5,600 rpm, and the no load voltage at the terminals is 26.2 volts.
    The spindle metal casing is 52mm diameter and 94mm long.
    Can anyone please tell me the rated kW, DC voltage and current of this spindle?
    The manufacturers are not responding
    regards to all,
    Jill
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    62
    Re: CNC 3040 Z-DQ spindle rating
    The image referred to above is not showing at CNCZone, so I am posting a link to the image at sister site Industry Arena: https://en.industryarena.com/forum/a...5&d=1678848817
    Jan 2005
    15331
    Quote Originally Posted by JillB99 View Post
    regards to all,
    Jill
    They range from 300watts to 600watts this sounds like yours is 500watts they are just a small DC motor with an ER collet adaptor, so you don't have a lot of power as such, if you program for light cutting loads they can do quite well.
    Mactec54
