585,749 active members*
3,875 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > CNC FADAL TAPPING PROGRAM
Results 1 to 6 of 6
    Nov 2013
    4
    Dear Masters,
    can you help me make program for tapping.
    my material is aluminum.
    i need to make tap M12 x 1.75 about 20mm deep.
    can you give me sample of programs that you used.
    thank you in advance.
    Apr 2005
    1194
    Re: CNC FADAL TAPPING PROGRAM
    This should help you understand the metric tap conversion for rigid tapping.
    1 inch = 25.4mm
    M12 x 1.75 = 1.75mm per rotation
    1mm = .039375
    So take 1.75 * .039375 = .0689 per rev movement in inches
    1/.0689 = 14.5137
    So for an spindle speed of 14.5137 your feed should be 1ipm
    You will need some surface speed to tap so lets spin 20 times that spindle rpm.
    Rpm 290.2757
    Feedrate 20ipm
    But fadal controls like to manage feed rate more than crazy decimals of spindle speed.
    So take 300/14.5137 (300 baseline rpm for this example) = feed rate 20.6701
    FADAL FORMAT 2
    M6T1
    GOX0Y0
    Z.2H1M8
    G84.1G98Z-.7875R.2S300F20.6701
    G80
    M9
    M6T2
    Jan 2015
    417
    Also download the Free Program codes quick Reference info handy 3 pages http://itscnc.com/images/Program_Codes_1.pdf or the MU command on the control
    Nov 2013
    4
    carbidecraters
    thank you for your response
    I have a few questions regarding on fadal format 2.
    since I am using millimeters as my unit on machine and CAM.
    should I change all to INCHES so the program will run?
    EX. I need to TAP 20 mm deep. = Z-.7875 (base on your sample)?
    how about my X and Y location?.
    - - - Updated - - -
    Rodney247
    thank you for the list of codes.
    Apr 2005
    1194
    Metric mode, if in MM per min
    M6T1
    G0X0Y0
    Z.2H1M8
    G84.1G98Z-20.R.2S300F525.
    G80
    M9
    M6T2
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Nov 2013
    4
    thank you again.
  1. Fadal vmc 15 tapping torque
    By Welder2022 in forum Fadal
    Last Post: 09-18-2016, 03:30 PM
  2. writing g-code program for fadal vmc for tapping and drilling
    By mrivera85706 in forum G-Code Programing
    Last Post: 08-31-2011, 11:23 PM
  3. High production rigid tapping on Fadal?
    By imaginemw in forum Fadal
    Last Post: 08-27-2011, 05:50 AM
  4. Tapping on Fadal from SurfCam
    By lkenney in forum Surfcam
    Last Post: 02-25-2011, 11:01 AM
  5. Fadal 4020 Rigid Tapping Limits?
    Last Post: 02-24-2011, 06:36 PM
