Selling my CNC G0704 with 12 tool ATC. Where on the forum do you list items for sale?
Items "For Sale" go in the Classified sub-forum,
https://www.cnczone.com/forums/newly...ieds-listings/
. . . which is where I have moved this thread to.
I see you posted some photos, but you need to add a price and the location of the equipment etc to interest buyers.
The machine works great and comes with a lot of extras. I have I think 18 TTS tool holders, brand new TTS fly cutter with inserts. The mill can be run with the touch screen on the console or with the remote pendant. The motors on this mill are the Teknic servo SD killers. I have extra motors as well. I have to TFEC motors that are brand new in the box that go with the mill. I also am throwing in a brand new Hitachi frequency drive. The Z axis has linear rails on it. The Z has nema 34 motor. Inside the console is a computer to get on the net via wifi. There is so many features with this mill. The mill software is Mach3.
I am asking $4000 for the entire mill plus extra parts. Contact me via here if you want to know more.
Jeff
Hi Jeff,
Where are you located?
thanks
Vic
The enclosure for this mill did not ever leak on me. There are 2 pans on the left and right that are angled so that the chips and coolant run into the middle into a slipped drawer that can be opened to scoop out the chips. The bottom rear of the drawer has a bung welded in that allows the coolant to go back to the coolant tank.
The power draw bar can be activated via the touch scree, hand held pendant, and or manual with air valve on the head. Just about every part on this mill, enclosure, head cover, console, electrical cabinet and air board were powder coated. The machine is like new. The spindle motor is the tread mill motor design and works great no issues at all. There is an M6 manual Macro and an M6 auto tool changer macro as well. Also in the macro and electronics is a pressure monitor that will code if pressure in the system drops below a set level. Lots of things done to this machine to make it trouble free. The mill base was ground flat and sits on a granite block in the enclosure.
