585,975 active members*
4,882 visitors online*
Thread: cnc HELP
    Jan 2021
    cnc HELP
    I bought a new 1500x1500 open builds workbee cnc router. I'm having a problem wiring the vfd so that mach3 software can work for me. i got the spindal working throught the vfd but nothing works in mach3 software.
    CAN ANY ONE HELP ME PLEASE, PLEASE
    Apr 2004
    5737
    Re: cnc HELP
    Are you using the Openbuilds relay box: https://openbuildspartstore.com/iot-...y-power-strip/ to turn it on and off? Or are you trying to control the speed using the 1-10v signal from the "black box" https://openbuildspartstore.com/blac...ontrol-system/ ? If the VFD is working for you now, it's in manual mode. To get it to respond to those 1-10v signals, you need to put it in automatic mode. There should be something in the VFD manual about how to do that.
    Andrew Werby
    Website
    Re: cnc HELP
    Quote Originally Posted by TheKid View Post
    You can post more information like VFD type and photos, the connections, any alarm code on the VFD? etc
