Good day everyone
We bought Gildemeister CTX 400 with Heidenhain CNC Pilot 4290
There is issue with machine start
I will describe chronology:
1. When we turn on machine, windows 98 show some errors after "blue screen of death" appeared. Unfortunately, operator did not saved firs errors, only BSOD photo we have
The machine was turned off, we decided to remove the image (clone).
2. When we found a suitable HDD IDE. We turned on the machine, the machine turnedon without errors. All OK.
3. We turn off the machine, after we removed the image (ghost) and cloned (acronyx). There were no mistakes.
The disc worked with a loud noise and we turned it off
4. Further manipulations were tried with the purchased SSD with IDE controllers and HDD.
Current HDD has like native 500 mA.
5. The BIOS sees the disk, the splash screen is loading, the W98 desktop appears and then when the virtual machine starts to load, than a "Error 2 can't load Vdx" pops up
I press "OK", the loading continues. And the second window flies out
"Unable to open Vxd x \\ PLX_90xx.vxd <, Error code2". photo attached
I afraid we have damaged disk image
I ask for your advice or maby some have disk image?
Regards Artem
