587,006 active members*
3,142 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > CNC Router spindle starts spinning after start up
    Mar 2016
    11
    Hello
    I have a Chinese made cnc router, it has been working fine for quite some time but today as soon as i power on the machine, the spindle starts spinning by itself and spins at high speed and I cannot even stop it by pressing the ON/OFF button on the DSP.
    Have to switch off the machine to stop the machine.
    Any idea what could be wrong.
    Thank you.
    Re: CNC Router spindle starts spinning after start up
    You need a breakout board that has Safety Charge Pump. Maybe this one will work for you:
    https://cnc4pc.com/c11g-multifunction-cnc-board.html
    You may be able to install an external one:
    https://cnc4pc.com/c4-safety-charge-pump.html
    It is basically a watchdog that monitors the controller to confirm that the signals are valid.
    Arturo Duncan
    https://cnc4pc.com
    Mar 2024
    30
    Quote Originally Posted by ecoworld View Post
    Hello
    Thank you.
    For syntec controller contact me at [email protected]/ +918168294379 (whatsapp)
  1. Huanyang VFD and Spindle starts spinning at startup
    By mrp192 in forum Spindles / VFD
    Last Post: 08-04-2019, 06:01 AM
  2. Spindle just stopped spinning.... cnc
    By potts43 in forum Spindles / VFD
    Last Post: 09-16-2018, 08:54 PM
  3. 6040 CNC spindle only spinning in manual mode
    By vosser in forum Chinese Machines
    Last Post: 08-09-2018, 07:18 PM
  4. Vcarve Pro won't start my router spinning
    By Gary-Wiant in forum PhotoVCarve and VCarve Pro
    Last Post: 09-04-2017, 04:39 AM
  5. Spindle won't start spinning on Multicam
    By lettersetc in forum EnRoute
    Last Post: 09-23-2015, 09:32 PM
