496,246 active members
5,607 visitors online
    Sep 2016
    33
    Cnc tooling feeds and speeds.
    Hi I just finally bought some good quality bits from Amana Tool and they have a special coating on them that is supposed to make them last longer. I was looking at their feeds and speeds recommendations and noticed for my 1/4 up cut spiral endmill the chiploadfor hardwood was at 0.0016 and that's seems low to me as I have been cutting hardwood and been running more in the 5X (0.005-0.009) range with cheap Chinese endmill. This this all depth=diameter Would the coating make the bit brittle or for any reason hinder me from making the same feeds and speeds? Or are they just being conservative with recommendations? I don't want to dull the bit with heat from too slow a speed... I like running 2 flute 1/4 inch bits at 14000 rpm and at 4-5m/min. Any other thoughts or concerns? Let 'em fly!
    Mar 2003
    32946
    Re: Cnc tooling feeds and speeds.
    Looks like their chart is wrong, imo.
    I'd actually run them faster. I run 1/4" spirals at 300-400ipm (7-10m/min) at 18,000 rpm.
    I have a couple 46348-K bits on my desk, but haven't used them yet.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2016
    33
    Thanks Gerry, that's what I wanted to hear!
    I hate going slow! I wonder if the charts are all wrong because they all seem to be way to slow....
  1. feeds and speeds
    By thurminator in forum CNC Swiss Screw Machines
    Last Post: 02-13-2014, 04:16 PM
  2. speeds and feeds
    By ponchosb77 in forum CNC Tooling
    Last Post: 02-25-2011, 11:12 PM
  3. Speeds and Feeds
    By fenix in forum Uncategorised CAM Discussion
    Last Post: 01-22-2010, 07:07 PM
  4. feeds and speeds
    By JpBinc in forum General Metalwork Discussion
    Last Post: 10-03-2006, 06:48 AM
