540,529 active members*
1,703 visitors online*
Results 1 to 15 of 15
    Mar 2021
    11
    CNC USB Controller slave issue
    Good morning all, I just started building a cnc router and ran into an issue with my software , using CNC USB Controller v. 2.10.1204.201, I can't figure out how to set a slave on my Y axis, I can create 3 axis with a forth slave but that doesn't work. I have a UCNCV4 controller FMD2740C drivers(4) and 4 23HS2430B stepper motors. In the initial stage so not installed on the machine yet.
    Any help would be great.
    Aug 2011
    49
    Re: CNC USB Controller slave issue
    I think you should set axis 1 - X, axis 2 - Y, axis 3 - Y and axis 4 - Z in settings axes.
    Mar 2021
    11
    HI, thank you for the reply. I tried but I cannot add the same letter in different axis.
    Aug 2011
    49
    I had 4 axis machine hocked to that old controller and because I needed all 4 axis, I simply split the Y wires from controller to two drivers and worked fine for me.
    Mar 2021
    11
    That can be a solution but I wouldn't be able to make any micro adjustments if the gantry wasn't track square. I curious to know if the issue is the controller card or the software? Can I use another software with this card?
    Aug 2011
    49
    If you want to use the slave axis then I think you should set number of axis to 3 and then the 4`th axis as slave.
    Mar 2021
    11
    That is what I want to do but have no idea how to do it in usb cnc controller software.
    Aug 2011
    49
    Just as I say in setting -> axes
    set on top Number of axes to 3
    then 1 to X
    2 to Y
    3 to Z
    and at 4 set slave 2 because axis 2 is your Y
    Aug 2011
    49
    OMG I read again your first post and you use UCNCV4 controller.
    I think you can not use planetCNC software with other controllers, only planetCNC controllers.
    https://planet-cnc.com/
    Mar 2021
    11
    I tried but when I go to settings, axes1 tab I have it set to 3 axis and all the rest of the axis and function rows are greyed out so I cannot add the A axis as slave.
    I do thank you for your replies.
    Mar 2021
    11
    Oh, that is what came with my package, cnc usb controller software. I can control the axis with the software but cannot set a slave. Is there another software I can use? Thanks again.
    Aug 2011
    49
    Sorry, I can`t help you, I have just used planetCNC software and controllers from when I build first CNC many years ago. Good luck.
    Mar 2021
    11
    Thanks.
    Stavmanxyz, I am also starting the process of setting up a UCNCV4 controller in my DIY cnc kit. I am in the wiring-up stage and I have some questions. maybe we can help each other.
    Moderator
    Mar 2017
    796
    You realize that UCNCV4 is Chinese clone of our Mk1 controller?
    And that software included is pirated version from 2012?
  1. Replies: 2
    Last Post: 12-22-2020, 02:32 PM
  2. USB Motion Controller Slave Axis Not Working
    By cncdotcom in forum DIY CNC Router Table Machines
    Last Post: 11-28-2020, 06:52 PM
  3. Syntec 6mb controller issue
    By djcregan in forum Chinese Machines
    Last Post: 10-28-2020, 07:16 PM
  4. Replies: 0
    Last Post: 11-13-2015, 04:37 PM
  5. Homing function slave issue
    By hsgreer in forum Machines running Mach Software
    Last Post: 06-03-2012, 06:02 AM
