Hi All
Thank you for valuable information...Im a complete newy to these machines..my main products will be mdf and acrylics....template and cabinet based....maybe some signage..I have cut a few things and it seems to be ok apart from me working out feed rates and depth of cuts...correct cutting tools....actually lots of things
The company is printed on the front...Acctek...the machine is completely hand made and you can see...there are lots of little...hopefully small issues to deal with...
I should have room for some counter sunk screws in the mdf on the sides as the bed is wider and longer than the cutting area.
You have brought to light the fact that the machine bed is only suspended from end to end...which is something I never considered/thought of...before making the purchase.
I think if it is unable to handle the materials I want to cut ( mdf, laminated boards, acrylic) I may look at reinforcing the beams with an extra steal c section welded to each side to increase the span weight capacity...depending on cost and current performance aswell....I may be able to add an extra servo and ball screw to control the y axis..spread apart to the sides..possibly allowing the cutting of the sliding beam.
Based on your feed back I am going to shim the bed on the rails...surface the rubber and add a 12mm mdf spoil board also surfaced and fixed down on edges beyond cutting capability.
cheers all still open to any more feedback.
