Feature of new design big size water jet cutter EK2060:
1 EAAK New design big size water jet cutting machine with large cutting size up to 2000*6000mm or 2000*8000mm.We can also customize 3000*10000mm refer to customer request.
2 This series of machine specially equips enhanced structure and upgraded transmission system,more suit for cutting heavy thick metal plate and stone plate.
Specification of big size 2000*6000mm waterjet cutting machine EK2060:
Model EK2060
X Y axis Working size 2000mm*6000mm
Z working height 150mm
Cutting Pressure 420Mpa 37kw UHP pump
Control accuracy 0.01mm
Cutting accuracy 0.1-0.2mm
Repositioning Accuracy 0.05mm
Max cutting thickness 300mm(depends on materials)
Max. moving speed 6000mm/min
Power supply 380V 50Hz
Environmental temperature -10-50°C
Max flow rate 3.7L/min
Max oil discharge 206L/min
Max delivery capacity of oil pump 106L/min
Control system Ncstudio IPC control system
CAD/CAM software AutoCAD,ArtCAM
Drive motor Japan Yaskawa servo drive motor
