529,699 active members*
2,432 visitors online*
Results 1 to 5 of 5
    Sep 2020
    5
    CNCEST 6040 ALL AXIS LOOSING STEPS
    So i just bought this particular machine https://www.ebay.es/itm/293746046167 . It comes with this usb control board
    Also the stepper drivers are TX14207
    I can comunícate with the computer throw the usb and mach3 to the machine. The problem is that the machine is missing steps on every single axis so it maked impossible to make any work...
    Things that i already check:
    Tighten the Z axis.
    Slowing down speed and velocity
    Calibrate the axis throw mach3.
    Different computer with different Windows (w7 32bits and w10 x64).
    I dont know what more can i do... Im so lost and this consume 4 full days of trials trying to figure the problem...
    As i said all axis can mové also the spindle but for some reason they are loosing steps.
    Machine is cncest 6040 ????
    Dec 2003
    714
    Re: CNCEST 6040 ALL AXIS LOOSING STEPS
    What voltage is going to the steppers?They may need more than they are getting.
    Sep 2020
    5
    Quote Originally Posted by routalot View Post
    Hello routalot. Actually here i have not a multimeter to check this but as far as i know. The voltage must be governed by the bsmce04u board right? So it must be ok? I will try to catch a multimeter to check it out. And let you know.
    Thanks for your help
    Sep 2020
    5
    Ok i got a multimeter and i did the measurements. all the stepper drivers are getting 23.9v and 1.151A from the powersupply. The motors wich i have are the nema 57 two-phase 3A 150N.cm
    Sep 2020
    5
    Any clue? Anybody?
  1. Z axis loosing steps
    By MikeTerasT in forum Uncategorised WoodWorking Machines
    Last Post: 05-16-2020, 07:03 PM
  2. Z axis still loosing steps?
    By PJRU0304 in forum DIY CNC Router Table Machines
    Last Post: 12-13-2018, 10:36 PM
  3. z axis loosing steps
    By jeffspin in forum DIY CNC Router Table Machines
    Last Post: 10-13-2017, 11:45 AM
  4. Z- Axis loosing steps
    By Flachzange in forum Mach Mill
    Last Post: 05-17-2012, 11:08 PM
  5. Axis loosing steps
    By Vogavt in forum Benchtop Machines
    Last Post: 01-07-2010, 06:01 PM
