544,161 active members*
2,868 visitors online*
    May 2021
    3
    CNCzone 3040z cnc usb files for Mach3
    Hello, I have read that the dll files for the controller are unavailable. I have successfully extracted the dll files for the usb controller, so it should be compatible with mach 3 now. Unfortunately, I will not be able to test this until later today/tomorrow.
    To use, place files in your mach3 directory. --please note this is the version for 64bit
    Attached Files Attached Files
    May 2021
    3
    Re: CNCzone 3040z cnc usb files for Mach3
    The files seem to work... Mach3 can read the position of the encoder. However, I cannot move any axis yet... I think the settings provided for the pins settings may have been only for when the db25 connector is used. Any assistance would be appreciated... I have an reconfiguration Estop error. The settings appear ok, as from a setup video, and the manual.
