531,717 active members*
3,243 visitors online*
Results 1 to 7 of 7
    Aug 2008
    82
    Question CO2 Laser types
    Hi
    Just getting back into Laser engraving and cutting after a few years away. Something that I can't seem to find an answer on is what's the difference between a c-series and an E-series or any othe series. Appreciate if someone could enlighten me.
    Cheers.
    Aug 2008
    82
    Re: CO2 Laser types
    Just found the answer. For those interested the answer lies not in the machine but in the Lens system. Confusion
    This is from Russ on his SarbarMultimedia YouTube channel:
    The difference is small and all to do with the lens tube diameter. The C series is 24mm diameter and is fixed to the head with a collet type clampring. The E series is 25mm diameter and is fixed to the head with split sleeve clamp and thumb screw.
    Nov 2010
    775
    Re: CO2 Laser types
    Quote Originally Posted by dvdlock View Post
    What nonsense.
    CNC lasers, constructions, service
    Aug 2008
    82
    Re: CO2 Laser types
    Quote Originally Posted by cinematic2 View Post
    What nonsense.
    Would you care to elaborate?
    Nov 2010
    775
    Re: CO2 Laser types
    Why elaborate a topic that is completely nonsensical and lacks basic knowledge of lasers?
    CO2 lasers.
    Aug 2008
    82
    Re: CO2 Laser types
    CO2 lasers.
    Oh, OK. So you were born an expert.
    No idea why you think it was nonsensical, it was a perfectly reasonable question. I had no idea what the difference between the two series was.
    I'm done.
    Apr 2020
    12
    Re: CO2 Laser types
    Your ? certainly seemed logical to me. Also thought you posting what you found out was courteous.
    Forum responses are usually friendly and helpful, but sometimes .......
    Bobby
  1. Three types of laser cutting machine
    By jackmiao in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-22-2018, 03:21 AM
  2. With types on types of fits on cnc aluminium.
    By chubchublolly in forum General MetalWork Discussion
    Last Post: 09-04-2016, 01:21 PM
  3. Two types of Laser cutting machine ,Which one you think will be better?
    By Lasercutter12 in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-30-2016, 04:42 AM
  4. Laser tube types.
    By ozstockman in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 07-04-2015, 04:34 AM
  5. Laser types used in manufacturing
    By Konstantin in forum General Laser Engraving / Cutting Machine Discussion
    Last Post: 06-20-2008, 04:03 PM
