547,544 active members*
776 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Command Multiplier (CMR)? Detection Multiplier (DMR)? Makes my head hurt.
Results 1 to 4 of 4
    Greetings fellow builders.
    Installing a 4th axis on a YCI Supermax with Fanuc OM-C control. I got most everything figured out but the CMR and DMR settings. There is also the Flexible Feed Gear settings on the Servo Setting Screen. There's got to be someone out there that does this in their sleep. For some reason I can't get it. Mainly because the possible numbers I'm allowed to use seem to have nothing to do with (exactly anyway) with the numbers I'm allowed to enter into the control. I know I'm missing something.
    FYI... running this in a style A (S1 jumper) setup where I'm connecting the encoder to the CNC directly and not using battery backup. Rest of the machine uses Alpha C6's with i10,000 encoders. (I think) I also believe I have a serial interface with digital servo function.
    Millimeter machine. (IS-B System) Least command increment_ 0.001mm/0.001deg
    Motor is Fanuc Alpha 12/2000 with built in Absolute 64K encoder. (A06B-0142-B075) (64K is 65,563 pulses per rev, or so I've read.)
    Tsudakoma RN-301 table with 180-1 reduction ratio. Meaning one rotation of the motor gives you 2 degrees rotation on the table.
    I think I know most of the settings needed for the servo setting screen, except as I said, the CMR, DMR, Feed-gear N & M.
    This has been a long process and I'm bumming for getting stuck near the end.
    Thanks tons to anyone that can help.
    David
    Apr 2011
    785
    Re: Command Multiplier (CMR)? Detection Multiplier (DMR)? Makes my head hurt.
    CRM should be set to 2, DMR should be set to 0. Used N/M as follows:
    Fanuc says to treat the 64K encoder as a 1000000 count encoder.
    The table accuracy is 0.001o, so one table rotation will be 360.000o on the position display, there are 360000 pulses desired.The gear ratio is 180:1, so the formula denominator of 1,000,000 is multiplied by 180. Fanuc also says to reduce the fraction numbers.
    FFG
    ....360000.............=.......360000.......=...1. ......N
    _____________..........__________.....____.......
    1,000,000(180).............180000000......500..... .M
    Thanks tons Dr. DOS! Couldn't have done it without you.
    I knew there had to be someone around here that had this under their belt. From your name I take it you're also a DOS afficianado too. Never hurts, even in this day.
    Thanks again...
    David
    Jan 2019
    Hi, I have a Chiron machine with 0M control, I have a problem in the travel of my axes, moving 0.01 inches with the indicator, the axes only move 0.005 inches and in Z moving 0.01 inches with the indicator, it only moves 0.008, investigating a bit it seems to me that it is the adjustment of CRT and DMR, but I do not know the parameters that indicate the adjustment, I would appreciate your help.
    e-mail: levh.control@gmail.com
  1. g code multiplier
    By vagelism22678 in forum G-Code Programing
    Last Post: 07-10-2010, 03:28 PM
  2. Step multiplier, Why use it ?
    By Larken in forum Viper Servo drives
    Last Post: 03-04-2009, 06:13 AM
  3. pulse multiplier
    By Beyazbalina in forum Stepper Motors / Drives
    Last Post: 03-25-2007, 10:37 AM
  4. Multiplier confusion
    By Mike F in forum Servo Motors / Drives
    Last Post: 01-03-2005, 08:36 PM
  5. G340 multiplier
    By gbon2 in forum Gecko Drives
    Last Post: 12-15-2004, 04:26 PM
