The attached indicate the 3/4" thick base of a wooden clock I will make (all in plywood). In the center there a slot which will accept the 3/4" thick clock frame. I'm confused with the comp. direction but I will say for the base perimeter cut I should select Right direction and for the slot cut I should select Left direction. Am I right?
The other problem I have is that I only have a 2 flute 1/8" cut diameter end mill with a max cut height of 1/2". So I will cut up to 1/2" deep and the rest I will use my jigsaw unless there is a place you may know selling the right end mill
Many thanks
