601,654 active members*
2,564 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Conquest 42 Fanuc 0T-C spindle orient parameters
    Apr 2006
    4
    I'm working on a machine that lost all of its parameters (and no serial number to be found on the machine anywhere) - I have nearly all of the Fanuc 0T-C manuals to reference and a set of 0T-B parameters from a slightly older machine that has gotten me 80+% of the way to working again, but I have a few pieces remaining.
    Machine has live-tool and sub-spindle - the live tool feature would've included spindle positioning, and it appears that the hardware is there to do it.
    I cannot get the spindle orient/positioning features to work, I have 2nd aux function turned on in the 900's, and have the D300 parameters turned on for the features. However I'm not able to turn on parameter 6515.1 (I key the bit into the parameter, but it remains 0) which should enable spindle orient/positioning.
    When I attempt an M19 or Bxxx command, I get an Er-05 on the spindle drive (Spindle Orient command received, but parameter is not turned on)
    Is there another 900-parameter I'm missing to allow 6515.1 to turn on?
    Apr 2025
    Re: Conquest 42 Fanuc 0T-C spindle orient parameters
    Hi Icesoft,
    I have the same machine with O-TC controler. But I have found some documents.
    If you still in trouble make me private message, I will give you my config up to 99% my only thing left is feed interlock on G1, G2, G3 fonctions but I think my lathe was downgrade beacause axe8 (subspindle) variator error and they made some hardware modification that i cn't trace... I'm witing for ladder program to download it and see what I can do...
    So I have to apologies about my pour english level because I'm french
    But I will help you if I can
  1. Conquest 42 / Fanuc 0-TC / Parameters needed
    By MorueM in forum Hardinge Lathes
    Last Post: 01-19-2023, 09:24 AM
  2. Mazak spindle orient parameters
    By Jfrahm in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-25-2021, 12:56 AM
  3. Replies: 2
    Last Post: 05-05-2019, 11:12 AM
  4. Conquest 42 Fanuc OT control, Spindle Orient
    By edeaton in forum Hardinge Lathes
    Last Post: 12-31-2015, 07:44 PM
  5. Hardinge Conquest T 42 FANUC 0T optional parameters
    By bobancurug in forum Hardinge Lathes
    Last Post: 09-20-2015, 04:17 AM
