Hi...I have a problem that if z is moved up, then xy moves in positive direction ..the xy looses steps....if then z is moved down, xy in same direction works fine....breakout board?....how do I test ... mach 3
Shielding on wires? Add a counter weight to Z so it is easier to lift... Z drive may be sacking power from X y?
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
Star type power distribution, out Daisy chained?
Sent from my Z958 using Tapatalk
