601,129 active members*
2,337 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Convention of the connector of MPG handwheel?
    I'm a Mechatronics student being familiar with electrical circuit, PLC and microcontroller. I want to build my own handwheel for my small project but still want some compatibility. Basically, I know the order of wires does not matter on the technical perspective. But what's the convention of connector?
    I suppose most of existing ones use DB (D-Sub) Connectors. On the handwheel side, should I use female or male connector?
    How should I wire my handwheel to the DB connector? I found this on the Internet. But I suppose the closest DB connector is DB25 which has 25 pins. How should I assign the pins?
    Attached Thumbnails Attached Thumbnails convention-of-the-connector-of-mpg-handwheel-v0-daxoleiqagoe1.jpg
    Dec 2003
    24235
    Re: Convention of the connector of MPG handwheel?
    If using Dsub, you should always use the socket for the power /input side.
    The output from the handwheel would be the male side.
    There is no real standard for pin consignment for particular pins on these , in my experience.
    Albert E.
    Jun 2005
    1739
    Quote Originally Posted by Al_The_Man View Post
    I would go to cnc4pc.com and download their manual on their mpg it is pretty standard with many you find on eBay
  1. [TNGv2] - Wireless handwheel (MPG pendant)
    By PlanetCNC in forum PlanetCNC
    Last Post: 07-18-2024, 05:29 PM
  2. DIY mpg handwheel for USB mach3 board
    By Andresgs3 in forum CNC "do-it-yourself"
    Last Post: 11-15-2022, 01:20 AM
  3. MPG Handwheel Pulse Multiplier
    By cgabel in forum Stepper Motors / Drives
    Last Post: 06-14-2021, 11:05 AM
  4. Handwheel command and MPG
    By precourt in forum CamSoft Products
    Last Post: 03-24-2008, 04:14 PM
