545,577 active members*
7,108 visitors online*
Results 1 to 4 of 4
    Conversion to Mach3
    Good morning, afternoon and night to all!
    Next guys, is it possible to convert the "SIEGE CNC MILLING MILL" software to Mach3?
    the machine is Chinese, and there is no type of physical or digital manual, I searched the internet all and nothing.
    NOTE: the machine is connected to the notebook via ethernet (RJ-45)
    the drivers are all Chinese and you don't find any technical information about them on the internet, what little you think is written in Chinese!
    will it be possible that I can control this mini cnc with mach3? someone specialist to help me? THANKS!
    attaches some photos
    Jan 2018
    800
    Re: Conversion to Mach3
    Not sure how easy it would be without changing controller (smoothstepper or UCxxx) and maybe a couple of other things.
    Might be as simple as needing a plugin but need to speak to sieg about that.
    What is the matter with it? Does it not work?
    A couple of useless bits I've found.
    https://wenku.baidu.com/view/20d2673...c_flag=default
    Use chrome for above and translate it.
    https://www.cnczone.com/forums/g-cod...20934-cnc.html
    http://www.siegind.com/Application/H...te/pdf/CNC.pdf
    So these use either fanuc, siemens or sieg software to control. Yours looks to have the Sieg cnc control software version 2.
    Why not shoot these guys a few emails to see if they can sort you out.
    SIEG has wide range of Light Industry CNC
    Dec 2003
    948
    Any particular reason for choosing the obsolete Mach3 over the current Mach4?
    Mar 2012
    Which model Sieg do you have?
    I have a Sieg KX3B and have managed to find a number of manuals and the control software for it.
  1. Dynamyte DM2800 conversion to Mach3
    By Robonut in forum Dyna Mechtronics
    Last Post: 02-14-2017, 01:10 AM
  2. DM-3000 Dyna to Mach3 Conversion
    By MRM RCModels in forum Dyna Mechtronics
    Last Post: 10-14-2015, 03:04 AM
  3. Dynapath to mach3 conversion assistance
    By RdHawg in forum Servo Motors / Drives
    Last Post: 10-24-2013, 04:24 AM
  4. Denford Orac Conversion to MACH3
    By adbradley in forum Benchtop Machines
    Last Post: 08-03-2009, 09:42 AM
  5. Mach3, BP Conversion, Appleton, WI Help
    By thosj in forum Mentors & Apprentice Locator
    Last Post: 03-31-2009, 10:58 PM
