540,709 active members*
7,607 visitors online*
IndustryArena Forum > CAM Software > CutLeader > Convert NC (G-Code) file to Cypcut
Results 1 to 5 of 5
    Sep 2011
    107
    Post Convert NC (G-Code) file to Cypcut
    NC-Convertor is a tool for NC converting, it converts G code for 2D cutting machine(laser/plasma/oxy/waterjet), the current version convert NC file to lxd file (Cypcut software). DXF files could be converted to Cypcut file also.
    This tool could be enhanced to convert between each kind of machine (GEN/START/FANLING/MESSER/KOIKE/ESSA/ESA and so on).
    Install .Net frame work V4.52 please if the software couldn’t be launched.
    Download link:
    https://dotnet.microsoft.com/downloa...amework/net452
    http://www.cutleader.com/download/NC-Convertor.zip
    Contact us please if there is specific requirement about the feature of the tool or supporting specific machine.
    Sep 2011
    107
    Re: Convert NC (G-Code) file to Cypcut
    This program could be used with DuctCAM, convert layout(DXF files) or NC files to your own cutting machine in batch. Improve the efficiency a lot.
    Nov 2020
    We are in the process of purchasing 2 laser tables with the Cypcut software. Can Cypcut work with Camduct from Autodesk Fabrication which produces CNC files wit G-Code?
    Sep 2011
    107
    Quote Originally Posted by alex360s View Post
    Hello, Cypcut could load G code file one by one, but not in batch mode. And user need rotate the layout manually, and couldn't filter lead in/out in the G-code. The Convertor we developed combine many G-code file into one task, and you could set the configuration to specifiy the origin position, layout rotation angle and so on. The machine operation then could run the cutting by one click in the Cypcut. It is far more efficient.
    Mar 2021
  1. postprocessor for laser machine with cypcut control
    By cutleader in forum CutLeader
    Last Post: 12-23-2020, 05:33 PM
  2. Program to Convert Mill g code To Laser g code - CMTL
    By doanwannapickle in forum Visual Mill
    Last Post: 02-20-2017, 06:08 PM
  3. How do you convert STL file from 3D printer to G-code or a CNC desktop mill file
    By imperial90303 in forum Uncategorised CAM Discussion
    Last Post: 01-25-2015, 08:37 PM
  4. Convert DWG file to DSTV file
    By benamer in forum Community Club House
    Last Post: 07-02-2013, 02:34 PM
