585,997 active members*
5,068 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > convert shopbot to another software/controller.
    Jun 2016
    5
    Good morning,
    I have an older shopbot PRS with an upgraded controller. I have had intermittent problems with it over the few years I've owned it bot primarily used it with a dragknife to cut vynal. recently it has gone haywire again. A friend suggested that i convert it to mach 3. I need to make this machine reliable and have the full range of abilities with the three axis machine. Any thoughts or recommendations would be greatly appreciated.
    John
    Mar 2003
    35538
    Re: convert shopbot to another software/controller.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2015
    686
    Without knowing your machine, you might also look at Linuxcnc. It has a broader range of hardware which may let you keep more of your machine intact to keep costs down.
    Rod Webster
    www.vehiclemods.net.au
  1. ShopBot Replacement Controller
    By islaww in forum For Sale Only
    Last Post: 05-22-2020, 10:26 PM
  2. Can someone help me find information on this shopbot controller
    By purecnc in forum Stepper Motors / Drives
    Last Post: 06-01-2014, 10:41 PM
  3. Convert the controller to inch
    By esadaddy in forum Fanuc
    Last Post: 01-10-2009, 02:55 PM
  4. Software to convert G-code to dxf
    By shekargernipall in forum Uncategorised CAM Discussion
    Last Post: 07-25-2005, 10:31 PM
  5. shopbot tools controller
    By najnielkp in forum DIY CNC Router Table Machines
    Last Post: 02-09-2005, 08:42 PM
