585,978 active members*
4,586 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Converting a very old Sherline to CNC - Build Log
    Aug 2004
    50
    I've had this old Sherline milling machine for a few years now. Never used it much and stopped using it all-together once my new Jet benchtop mill was setup.
    Being basically lazy I procrastinated a long time putting off the effort to sell the little Sherline. I'm kinda glad I did not. I'm going to convert it to CNC and get some experience with CNC and the little mill.
    I recently ordered the mechanical parts kit from Sherline to make the conversion. Since I want to run this off a modern PC without a parallel port I'm going to use a GRBL compatible board for control over USB.
    The Sherline parts arrived in the mail yesterday. This afternoon I cleared space on a workbench and began disassembly.
    Here's the base machine before any molestation.
    Attachment 463960 Attachment 463962
    Right away I ran into a couple of issues. #1 being my 8-32 tap appears to be worn out and will not cut. No worry. Trip to the tool store fixed that. The bigger worry is the machine is quite old and has one-piece lead screws on the X and Y. This means I either need to machine the ends to match current or drop the $40+ on new parts (shipping etc)
    Have not decided. I'll likely try machining them first. Worst case is a parts order.
    More to come later.
    Mike N
    No good deed goes unpunished.
    Mar 2009
    1982
    Re: Converting a very old Sherline to CNC - Build Log
    What is accuracy / repeatability? Small machine is effort worth if it can cut with micron accuracy.
    Aug 2009
    1573
    ...sell it. make more room
  1. Build log - my hobby CNC build
    By steprepeat in forum South Africa Club House
    Last Post: 05-11-2017, 07:00 PM
  2. nickswimsfast's CNC Build Log
    By nickswimsfast in forum CNC Wood Router Project Log
    Last Post: 11-25-2012, 09:13 PM
  3. New CNC router build log
    By victoria_jay in forum DIY CNC Router Table Machines
    Last Post: 03-21-2011, 10:57 PM
  4. Jgro cnc build Log
    By tbenefi33 in forum Commercial CNC Wood Routers
    Last Post: 10-19-2010, 09:17 PM
  5. converting a sherline 5000 to cnc
    By conradpi in forum Benchtop Machines
    Last Post: 10-13-2006, 08:00 PM
