548,466 active members*
2,513 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > converting an old beat up grinder into a horizontal mill
Results 1 to 12 of 12
    Apr 2007
    252
    this project has been going on for a few months now when time permits. this all started when my employer decided to get a different small surface grinder since this one has seen better days. by the time i ended up with it some key parts had been taken off the machine so restoring it would have cost to much and to be honest i am not a fan of swinging handles on a grinder. so after looking at it for a bit i decided to work on converting it into a small horizontal mill. i had a lot of spare parts so buying parts was not needed so much. if nothing else the 1,500lbs of machine made for a good base to build from for a small mill.
    the cast iron head of the grinder was big enough to fit a BT30 spindle tapper in so that's the plan for the spindle. the original motor was only 1 HP so that is being upgraded to a 3HP 3 phase inverter duty motor running off a VFD and am planning on a power draw bar with an air cylinder. no plans for any ATC just something set up for quick manual tool changes.
    if nothing else this should be interesting at the very least it gives me something to tinker with and keeps me out of trouble some pictures of the busted down machine. if the machine was not free i don't think i would do this but since it was nothing ventured nothing gained is basically how i look at it now.
    Attachment 472726Attachment 472728Attachment 472730
    Apr 2007
    252
    Re: converting an old beat up grinder into a horizontal mill
    this just a progress pictures over the last 3 1/2 months of me working here and there on the weekends. the mechanics of the lower end is pretty much sorted out, the Y axis for a horizontal configuration is probably the most difficult. direct drive of a screw to lift the head is not an option so that part is on going at this point, this was just a rough assembly to get an idea of travel and where things will fall when i get done.
Name:	rough assembly.jpg
    Apr 2007
    252
    thought i had the inside nailed down but once i took my shaft out and test fit the draw bar i soon realized i had to go back in and rework the section that allows the pull stud clamp to open up. i'm not sure what happened there but it's fixed now. it's easier to take a little more off than to put a little more back on with out messing something up
    only thing to do with the shaft at this point is to add some drive dogs for the holders. it would be nice if i can avoid cutting into the taper but that would have probably been easier to be part of the shaft. the older machines seemed to have bosses milled into the taper but the newer machines all seem to have a one
    piece construction and the taper is not touched.
    knowing me i will just probably cut into the taper since that would be the easiest way for me to add them. i can keep the bosses shallow and still have good engagement with the two drive dogs.
    working on the labyrinth seal for the front now but just started working on that part before i ran out of gas for the day
Name:	spindle shaft almost done.jpg
Name:	spindle shaft almost done 2.jpg
    Apr 2007
    252
    i guess i should have included a picture of the cast iron head the original spindle was in but did not think to include it. since the head was set up for a grinding wheel rather than a cutter spindle i ended up taking about 3.5 inched off the length of the casting. some of the length i will get back and by the time you add a tool holder to the spindle it will probably end up sticking out to about the same place as the original. but the altered casting should make for a more rigid machine. after the holiday i hope i can get the casting bored out and start putting things together so i can see a final result for run out. it looks pretty good so far but it's hard to tell for sure until things start going together. i am hoping for about .0002 or better but time will tell.
    Attachment 472840
    Apr 2007
    252
    i managed to get a decent amount done over the weekend but not as much as i would have liked too. i added some drive dogs to the spindle finished up the labyrinth seal and mounting to the casting for the head. i then realized i would need some kind of spring retention cap on the drive side of the spindle shaft so i sorted that out. when i had things together for what ever reason i decided to check the amount of ejection stroke needed and noticed the stoke was longer than expected. so to fix that i will have to rework one section of the internal work on the shaft to shorten that up some. the shorter the better so you can keep as much of the spring holding force as possible and not waste it on travel for the holder ejection. so getting that nailed down is the next step and then some kind of end cap on the draw bar to protect the treads then i will have the shaft finished completely.
    was able to see a collection of parts together to see what the front end is going to look like finished so i figured i would share some more pictures to anyone following this project
    Attachment 472978
    Attachment 472980
    Attachment 472982
    Attachment 472984
    Attachment 472986
    Attachment 472988
    Jan 2005
    13131
    Quote Originally Posted by machinedude View Post
    Attachment 472978
    Attachment 472980
    Attachment 472982
    Attachment 472984
    Attachment 472986
    Attachment 472988
    Looking Good, similar to my horizontal build.
    Mactec54
    Apr 2007
    252
    i wish i could move faster and get things done but spindles are are precise and that takes time. i wanted to have the head bored out and start thinking about putting things together but the rework and extra parts were not expected so that has me set back another weekend at least. the labyrinth seal was being difficult since it was 316 S.S. and the material i had was way to thick and needed cut down a lot, things were moving around as result so that sucked up some of my time as well chasing that around to get flat always something it seems
    Jan 2005
    13131
    This is normal when you build something like this, time is something you should not think about. one off parts, take longer as if you mess up you have to start all over again.
    As you can see in my Horizontal build the Spindle is similar.
    why the use of 316ss?
    Mactec54
    Apr 2007
    252
    it was the only thing i could find that was big enough to make it from and i did not want to have to buy something. i did not really have a budget for this project so any way to save is a plus. takes more time but i save a few bucks here and there which adds up over time. so to sum your question up in a nut shell i'm cheap
    Jan 2005
    13131
    I don't believe that is being cheap, using what you have, is good, material is expensive, I have been doing the same, for some time. it's better to turn the material you have, into something than it just sitting on the shelf, gathering dust.
    Mactec54
    Aug 2009
    1130
    ...interesting build....have you had any thoughts about a counter balance for Y axis?
    Apr 2007
    252
    Quote Originally Posted by machinehop5 View Post
    i may not need any kind of counterweight so as of now my plan is to just try without one and see how it does? i plan on using 750W servo's all around with a 5mm pitch screw so they can handle the weight i think but i will have to see first hand how it does and go from there. the Y axis is going to have some weight to it no doubt but i think it should only be around 400lbs at the very most taking a guess of course the 3hp motor alone is close to 50lbs but about the same as the original direct drive 1hp that was on the grinder to begin with.
    i will cross that bridge when i get to it right now i have a long list in front of that part but the possibility has crossed my mind that i could have a need for a counter weight of some sort.
  1. Horizontal Mill
    By MortyNTenon in forum Milltronics
    Last Post: 04-30-2018, 03:44 AM
  2. How to bore and mill a hole on Horizontal Boring Mill
    By SatishNaik in forum News Announcements
    Last Post: 11-11-2013, 07:29 AM
  3. How to drill and face mill using table type horizontal boring mill
    Last Post: 10-09-2013, 01:10 PM
  4. Converting a Manual Surface Grinder to a CNC
    By Left4Dead in forum Uncategorised MetalWorking Machines
    Last Post: 04-19-2010, 06:00 PM
  5. Atlas horizontal MI mill
    By toneV8 in forum Uncategorised MetalWorking Machines
    Last Post: 04-30-2009, 06:59 PM
