585,975 active members*
4,957 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Converting Chinese WM210v Lathe to CNC
    Dec 2017
    Hello guys,
    I'm going to purchase a Chinese WM210v mini lathe. My main focus with this lathe is to produce HTD5 pulleys made out from Aluminium 6061.
    I would like to convert this machine to work as CNC, adding Nema23 motors to the X and Y axis. Controlling the the lathe motor, including the X and Y axis, will be done with TB6600 or DQ542MA.
    I have few questions about the conversation process.
    1. This is the lathe motor (850w) - Aliexpress. If I'll connect the marked connector wires to a stepper controller, do you think it will work and I'll have the ability to control the motor steps?
    2. As for the X and Y axis , does anyone have any experience with doing so?
    Re: Converting Chinese WM210v Lathe to CNC
    Quote Originally Posted by Style View Post
    Hello guys,
    It is better to get the full CNC retrofit kit including the CNC controller, AC servo motors and drivers, with all the cables and connectors ready, and it is the way to get the best performance and best compatibility.
    Dec 2017
    Quote Originally Posted by cncmakers001 View Post
    You’re correct, but I wasn’t able to find such a kit for the WM210v lathe.
    If you are aware of any, I would like to see it.
  1. Converting a chinese C02 laser ...
    By pierrem in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-19-2013, 08:08 AM
  2. Converting a Chinese CNC from NCStudio to Mach3
    By dennis.keeling in forum Machines running Mach Software
    Last Post: 05-16-2013, 06:00 AM
  3. Converting a chinese laser
    By Khomouda in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2012, 02:17 PM
  4. Converting Chinese CNC router from DSP to Mach3
    By JohnCo in forum Australia, New Zealand Club House
    Last Post: 09-12-2009, 10:18 AM
  5. Converting Chinese laser to run 8 bit engraving
    By JimMacNab in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2008, 08:09 PM
