473,313 reg. members
Results 1 to 4 of 4
    Oct 2004
    3
    Converting to an EIA. file
    Hello guys,
    We just bought a 2008 510c-2 nexus matrix. It does not read our programs generated from Gibbs. I called Mazak they said we have to convert the file to an EIA. file The person I spoke to said all we had to do was to change it, well how do we change it we tried everything? Any helpwould be greatly appreciated!
    George
    May 2003
    262
    Rename the file to .eia in your Windows explorer
    Right click and pick rename.
    *Registered User*
    Oct 2013
    62
    and place the PROGRAM.eia inside of a folder on you USB.
    E:\FOLDER\PROGRAM.eia
    Jul 2011
    9
    In GibbsCAM, go to:
    File
    Preferences...
    File (Tab)
    Under File Extensions, you can change the Post: from NCF to EIA. Now every time you post, it will automatically post as an EIA.
    I was concerned that the EIA file extension would not work on the rest of our machines (Mori's, Haas, etc...) but all of our machines accept EIA's.
  1. Replies: 8
    Last Post: 05-04-2015, 12:49 PM
  2. Converting DWG file to a PDF
    By Perfect Circle in forum Autodesk
    Last Post: 02-28-2011, 06:25 PM
  3. Converting a pdf file to UG part file
    By gaoxingdcf in forum UG NX
    Last Post: 05-20-2010, 01:47 AM
  4. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  5. Converting a .max file
    By DAB_Design in forum Uncategorised CAM Discussion
    Last Post: 01-28-2005, 07:00 PM
