585,712 active members*
3,780 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Coolant and Blow air issue in VMC -Fanuc oi
Results 1 to 4 of 4
    Exclamation Coolant and Blow air issue in VMC -Fanuc oi
    Hello all,
    I have worked a few years in maintenance, but I faced a technical problem in milling machine VMC-Fanuc-oi, which is the "Blow air and Coolant" not working, I checked the keeprelays but the button in manual still not working. what is a parameter for coolant and blow air? any help !
    mus
    Jun 2021
    25
    Quote Originally Posted by DrMustafa View Post
    Hello all,
    mus
    Start by looking in the wiring diagram of the machine. Find the signal address for that button and then watch the ladder or signal status page to see if the contact/address is changing when you physically press the button.
    If the button works, you’ll have to look into the ladder logic to see what is/isn’t turning on/off and is preventing it
    Re: Coolant and Blow air issue in VMC -Fanuc oi
    actually , I am not into ladder programming, is there a parameter number for the coolant and blow air?
    Jun 2021
    25
    There won’t be a CNC parameter for “coolant and blow air” but there probably will be a PMC parameter for it in the form of a keep relay, timer, counter, etc. Those PMC parameters are used by the ladder so no matter what, you have to work out the logic for the coolant and blow air in order to figure out why it isn’t turning on or how to bypass it.
  1. Thru-spindle air blow design flaw?
    By myhäje in forum Okuma
    Last Post: 07-07-2016, 03:24 PM
  2. air blow
    By kjac62 in forum Okuma
    Last Post: 12-01-2011, 05:54 PM
  3. Multus Air blow
    By ChattaMan in forum Okuma
    Last Post: 09-26-2011, 12:59 PM
  4. how do I add air blow to automated omniturn?
    By paulcnc44 in forum G-Code Programing
    Last Post: 04-14-2010, 07:59 PM
  5. adding timer for Air blow
    By sting007 in forum Fanuc
    Last Post: 09-07-2008, 08:38 PM
