554,027 active members*
2,412 visitors online*
Results 1 to 5 of 5
    Oct 2021
    Coolant Pump Upgrade
    Just added a Tormach (stock) coolant pump, and it is quite pathetic in terms of pressure and flow rate. Is there a forum consensus of a more powerful aftermarket pump? Is the mechanical interface a standard of some sort?
    Thanks!
    Dan
    Re: Coolant Pump Upgrade
    Quote Originally Posted by dschmid4 View Post
    Thanks!
    Dan
    Hi Dan,
    What machine do you have ?
    First thing i would do is change out the standard line to 5/8 ID Hose.
    The flow will greatly increase,
    Secondly i would look into some kind of filter to stop the nozzles from being clogged with chips.
    Also, check out LMD-NC.com
    We make coolant rings for the Tormach machines that give 360 coverage and work with the ATC
    Paul
    Gold Member
    Jun 2006
    3063
    Folks on the Tormach Facebook groups seem to like inexpensive sumps for use as coolant pumps.
    Jan 2018
    1472
    Quote Originally Posted by MichaelHenry View Post
    I use a sump pump on my diy mill.
    They're very strong. I have a 400w and it's that powerful I had to fit a diverter pipe in-line to drop the pressure.
    Cost me £30gbp at the time 3 years ago.
    Mar 2020
    213
    Check the facebook groups. I and several others have posted links to upgraded pumps available on amazon and through other retailers. Pretty simple to do.
  1. Replies: 8
    Last Post: 08-09-2016, 04:55 AM
  2. What does 3/4 hp pump upgrade come with?
    By aadrew10 in forum Haas Mills
    Last Post: 12-09-2010, 07:12 PM
  3. coolant pump
    By JACKSMACHINE in forum Fadal
    Last Post: 05-22-2008, 09:13 PM
  4. upgrade coolant pump
    By alabat in forum Daewoo/Doosan
    Last Post: 02-06-2007, 07:40 PM
  5. Waylube pump upgrade
    By AndyB in forum Fadal
    Last Post: 06-10-2006, 03:25 AM
