Mac:
You may have just gotten a defective bearing. With the rolling-contact load that outer race is seeing, it wouldn't take much of a surface or material defect to start a fatigue crack. Keep in mind that ball bearings aren't really intended to be used in this way, with rolling contact directly applied to the outer race. Ideally, they'd be fitted into rollers (like a cam follower) that take the contact loading. Such rollers typically aren't hardened as much as bearing races, and aren't as brittle. Not criticizing the design. Just pointing out a possible explanation. Going to a higher ABEC rating won't change this, as that only has to do with the tolerances of the bearing, not it's alloy, heat treat, etc.
You might check your rail to make sure there isn't a burr or piece of foreign material on it. Assuming the bearing didn't slip, the same point on the bearing's outer race would have to roll over that spot repeatedly, which might have caused the crack.
No signature I would write will fit on only two lines.
