594,860 active members*
5,629 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > crying over servo that works with small drive but not w/HBS860H, only bumps cw/ccw
Results 1 to 7 of 7
    Jan 2022
    11
    Hello everyone.
    These last few days I have been trying to hook up a chinese nema34 hybrid servo motor 86HB250-156B with a Hybrid Servo Drive, and a Mach3 Board to test it.
    After wiring everything as supposed, I started running into some issues where the drive does move right/left but somehow the Mach3 Parameters are not being well fed to the driver so it crashes after just a slight turn (20 degrees or so)
    After a few tries i decided to test it with a smaller drive, suitable for nema23, and the motor works PERFECTLY fine, but the driver doesn't have enough voltage to run the motor at decent speeds and isn't ready for the encoder.
    I also didn't succeed with the encoder cable removed or different pinouts in pulse/rev.
    If anyone has an idea of what could be going wrong, please advise me, as i'm just a noob
    The small drive, the hbs860h drive, my mach3 settings and a small video of the error is shown in this imgur link: https://imgur.com/a/mzHMWJ8
    Thank you
    Attached Thumbnails Attached Thumbnails WhatsApp Image 2022-04-14 at 8.57.04 PM (1).jpeg   WhatsApp Image 2022-04-14 at 8.57.04 PM.jpeg   WhatsApp Image 2022-04-14 at 8.57.03 PM.jpeg   WhatsApp Image 2022-04-14 at 8.57.03 PM (3).jpeg
    WhatsApp Image 2022-04-14 at 8.57.03 PM (2).jpeg   WhatsApp Image 2022-04-14 at 8.57.03 PM (1).jpeg   WhatsApp Image 2022-04-14 at 8.57.04 PM (2).jpeg
    Jun 2013
    445
    Re: crying over servo that works with small drive but not w/HBS860H, only bumps cw/cc
    Is your driver flashing red 7 times? Im pretty sure its encoder. Double tripple check the encoder wiring. Along with the other wires. I bet its that mate.They need to be exact.
    Do you have a driver programming lead and software? If you do, and your wiring is perfect. Login to your driver and take it off closed loop mode. See if it runs then.
    Sent from my SM-N970F using Tapatalk
    Jan 2008
    1555
    Is the problem the same if encoder cable removed?
    Same 20 degrees?
    Likely the closed loop stepper driver is not seeing the encoder and is stopped when it reaches the following error limit.
    Feb 2023
    Hello everyone,
    I bought the exact same setup over a year ago but didn't use it until these days. Now I am unable to get it to work. I am having the same issue and would like to know if you could resolve it.
    Regards
    Mario
    Mar 2016
    Did anyone solve this issue. having the exact same problem
    Apr 2016
    8
    I have had the same issue with the same driver and hybrid motor.
    It had the error light flashing 7 times noting a encoder error, and when it operated it only worked for maybe 5 to 20 deg and very glitchy then stopped.
    I played around with a lot of wiring and finally switched over the encoder
    Eb+
    Eb-
    Ea+
    Ea-
    Wires, keeping the polarity correct but swapped over the eb pair with the Ea pair and everything worked as it should.
    What a relief.
    This may have been fixable if I had connected it with the rs232 cable and software but I didn't have the cable on hand.
    I hope this helps others as I couldn't find anything else online.
    Peter
    Apr 2016
    8
ID:	509981Click image for larger version.
    Attached Thumbnails Attached Thumbnails 20241102_161850.jpg   17305248498362131639498008400904.jpg
  1. Need small wood works g-code sample
    By shaikatraihan in forum CNC Wood Router Project Log
    Last Post: 10-25-2017, 12:45 PM
  2. Step direction signal converted to CW-,CW+, CCW-, CCW+
    By ok engineering in forum Servo Motors / Drives
    Last Post: 06-16-2017, 12:01 AM
  3. CNC 3020T-DJ, Works Great, Couple SMALL Questions...
    By kb0nly in forum Other Machine Topics
    Last Post: 09-17-2014, 03:03 AM
  4. Is the Roland mdx 540 a good cnc for small works?
    By tomislav_kozul in forum Benchtop Machines
    Last Post: 09-22-2010, 01:40 AM
  5. Drive has CW/CCW, need to hook to LPT
    By foam27 in forum Stepper Motors / Drives
    Last Post: 05-20-2007, 02:25 AM
