Hello,
I am using a VEVOR model AT1-220X inverter for use with a VEVOR JST-JGF-2.2KW-ER20 spindle motor (220V, 400Hz, 7.8A). The setup process wasn't too bad, and I am able to run the motor up until it reaches about 10Hz, at which point it throws "Error 01" which is listed as "short circuit / current overload / power module protection." I've already checked to make sure there are no shorts, and the wiring is correct for U/V/W between the VFD output and the motor.
I've tried playing with every parameter I can, and nothing seems to be fixing the problem. I even got a replacement motor, thinking that the first one must have been faulty, and the problem still occurs. As it stands, I am primarily concerned about parameter P67 - Voltage Coefficient and P76 - Current Coefficient. The manual lists the default for P67 as 28500 and P76 as 28000, but there is no explanation of what these values mean. Does anyone have experience with a problem like this, or at least know how I can find out what my voltage/current coefficients should be?
I'm an optics guy and this entire topic is new to me, so sorry if this is a silly question. I'd greatly appreciate any help you can provide.
Thanks,
Nate
